Out Of Control
RE: Out Of Control
Is ure buggy an Inferno? It looks like one (the colour of the radio tray gives it away). Oh, and where was ure failsafe by the way.
NH
RE: Out Of Control
The radio tray on alot of buggies are blue. My ofna 9.5 has a blue tray as well. Oh and you think thats an interesting bend. I got another for ya. Can anyone think of how I bent a brake disk. This is one of the ones on the rear. The trick is I only bent the outer of the two rear disks. Wierd dont you think..
RE: Out Of Control
Stu
it might be worth checking your chassis is still straight!
the centre driveshafts only bend when the chassis flexes right back[X(]
just take your wheels off & press it down on a flat surface & take a look
might be worth getting some decent chassis braces
Banned
RE: Out Of Control
Mmm. I was gonna go there. I would say the chassis was mangled aswell. Maybe a lot more damage if you strip it down more (gearbox mounts, Steering posts etc..).
Bent 1 brake disc, wierd, any stones in there? You must have a 10 tonne/cm servo in there. Or the disc was warped when you fitted it. Maybe it just overheated and warped like a 1:1 disc. Oh
well they're cheap and easy to replace.
RE: Out Of Control
could be a storm too.
lucky bum if you hit a wall and only bent a shaft. is it a cvd or a dog bone? surprised no plastic gave way at the "site" of impact.
1 Post
RE: Out Of Control
I forgot to reset my failsafe through my transmiter and the shark got it right except its not an inferno sport they have blue chassis plates. By the way everything else is fine. The first thing i thought when i saw the bent shaft was that i must of bent the chassis but i didn't some how
RE: Out Of Control
ORIGINAL: Model Mania
