Clutch bell question
CT
I recently stripped my clutch bell (bad gear mesh), so I bought a new one, but this one does not have the little vents in it. The last one did, if it isn't vented, will I see much of a difference?
RE: Clutch bell question
I have run both types and don't think the difference is noticeable, except for maybe a 30 minute main, but by then, the shoes are screaming for mercy anyway.
the bearings or the clutch shoes? why would the bearings heat up unless its not shimmed properly and both the inner and outer race are touching something
ORIGINAL: scale_only_4_me-RCU
Shark, Are you stalking me?
The clutch bell bearings are in contact with the clutch bell
Thus when the bell and shoes get overly hot the bearings also get hot
Heat bad, cool good
This is toy car racing not Rocket Surgery
Heat bad, cool good
I think the bearings will get more heat from the crankshaft than the clutch and clutchbell.
My Feedback: (158)
ORIGINAL: theShark lol... some guy on this forum said the bearings heat up when they start spinning at 40,000rpm
And further more
Why do you need to "Bait" anyone?
This is Gsir8's thread asking about the pros and cons of vented clutch bells
Why don’t we all just state an intelligent opinion or an apposing opinion or move on, Please
All this harassment just puts people off.
People come here for help, not to read a bunch of arguing back and forth
Banned
shark, nitrokeebler, Bait me some more jackass...And bearings do heat up, how long have you been in this hobby? Jackass!!!!
You honestly need to think before you speak! Both of ya's!
discussion
\Dis*cus"sion\, n. [L. discussio a shaking, examination, discussion: cf. F. discussion.]
1. The act or process of discussing by breaking up, or dispersing, as a tumor, or the like.
2. The act of discussing or exchanging reasons; examination by argument; debate; disputation; agitation.
I in fact don't even care to correct or argue with gcoupe, but the fact that someone else might come along and read his post and think that he is correct and use his advise because nobody challenges his point is what bothers be. Posts that only say this sucks and this is better than that are spam, and I think are worse than when people create more than one thread to ask the same thing. Reasons should be given why with links if possible or whatever.
CT
Ya, I agree with scale, because when metal heats up, it heats up the whole metal not just where the shoes are, and that is the only way they can get hot. I think I'm going to go back to the vented though, because I ran it today and almost seemed like the bell was gonna melt. Think its because I'm running aluminum shoes.
I am not sure of the even trade-off here, but approaching this as though you are bashing, you shouldn't have anything to worry about as far as the bell not being vented.
If this is a long term thing for you, and you want to buy one that is going to last a long time, you will have much fewer run-out worries with a non-vented bell because there is more material to dissapte heat.
I'll run heats with both and post the temperature results. This is kind of interesting.
My Feedback: (158)
ORIGINAL: fourboltmain
If this were true, why do engine have cooling fins?
If your stated theory was correct, the engine heads would be one big solid block of aluminum
The vents allow air circulation which is what actually help disapate the heat
LOL,
You are incorrect. The cooling fins on an engine give the engine more surface area. Maybe "material" in my previous post was a bad choice of words. But the more surface area exposed to the surrounding environment, the cooler it will be. So if you showed me clutch bell with cooling fins on it I'd say yeah you're right as rain, but in this case, you're wrong. Sorry.
Banned
It's like Total crap!
But back to the post, No-one has mentioned the other plus of vented bells, that there is less rotational mass to spin up so accel is improved on those tight tracks, but as mentioned do you really want crud and fuel on your shoes in that main.
Scale, the vent holes are there because people like you think they are whiz-bang. The theory that you postulate about the clutch bell's ability to circulate air is not feasible. (PM me if you need help understanding this) When is the last time you saw a brake drum with ventilation holes in it?? They have cooling fins. Something clutch bells do not have the luxury of being designed with. There is a reason why brake drums have been that way for umpteen years, but hey let's not get into physics, this is just toy car racing, so take your own advice and let it rest.
