RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
Pipes
Old 05-10-2004 | 08:21 AM
Default Pipes
Can anyone tell me which is the better pipe ?
RB Concept 9863 or OFNA 063
Any advantages with either pipe or is it just the name ?
Old 05-10-2004 | 08:33 AM
Q8 RC's Avatar
Default RE: Pipes
RB pipes are so good and they have that nice tune so i go with RB Concept 9863
Old 05-10-2004 | 10:49 AM
Default RE: Pipes
I wish pipes werent so expensive []. Right now a Pipe is the last thing on my list. I need new tires, a new chassis, and new shocks. One of my rear shocks blew out and I didnt notice so it was really flemsy and I drove it around for a while and it scraped up the rear end of the chassis so its like 2/3 or 1/2 the normal thickness and the screw holes are starting to bulge out.
But the sad thing is I can only afford one of these 3!!!
Anyways, back on topic. The stock Storm pipe is really loud, plus everyone says it sucks. Any DECENT replacement pipes for around 30 dollars or less? Should I check ebay?
Old 05-10-2004 | 11:42 AM
Default RE: Pipes
Any one give me advise PLEASE
Old 05-10-2004 | 12:21 PM
fourboltmain's Avatar
Default RE: Pipes
After I moded my Ofna 063, I would say that it is better than my RB. Look at the "If you have an OFNA pipe and want more power..." thread.
Old 05-10-2004 | 12:27 PM
Default RE: Pipes
Yeah fourboltmain i have read that thread its i have the chance of an OFNA 063 but the RB is a little more £s
just wondered if there is an advantage to either pipe
Old 05-10-2004 | 05:17 PM
sh0wtime's Avatar
Default RE: Pipes
yes there is a slight power advantage from using the RB pipe
this is due to the different resonance of the materials used in construction & as we all know 2 stroke engines are very sensitive to exhaust tuning!
go for the pipe that has been developed & tested & even manufactured to be the best[8D]
or the pipe that is a sub standard copy that needs grinding out due to poor quality manufacturing[:'(]
have you seen how off centre those manifolds are[X(] to sell that as a performance enhancing upgrade is almost a case of fraud
Old 05-10-2004 | 06:43 PM
Default RE: Pipes
If compression waves and expansion waves reflect whenever strikng the end of a closed chameber, why would it matter what alloy the aluminum is?? I have both an RB and an OFNA 063 and since the mod, the OFNA feels like the beefier pipe. And I am able to perform a straight A-B test. Please explain your resonance theory.
Old 05-10-2004 | 09:18 PM
Limegrntaln's Avatar
Default RE: Pipes
I can vouche for the Ofna pipe the mod kicks, there is no way you can justify the price of the RB pipe versus the ofna pipe, you can buy 2 ofna pipes for the price of an RB pipe. I say if you have the RB cash get a 063 and a 086 ofna pipe, then you can have whatever you want..
Old 05-11-2004 | 12:30 AM
sh0wtime's Avatar
Default RE: Pipes
ORIGINAL: fourboltmain
its been posted up on the RB forum many times by many different people! if you go over there & do a search you should find everything you need to know
Old 05-11-2004 | 12:51 AM
sh0wtime's Avatar
Default RE: Pipes
i just went to the RB forum & did a quick search on the words "Ofna pipe"
[link=http://rbproducts.com/rbww/ubb/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=1;t=001329#000000]HERE[/link] is just 1 out of about 20 results on this topic
i have slso read a more detailed analysis on this difference in materials but cannot remember where i saw it
it was possibly on the Serpent Forums at www.mytsn.com
now those on road 1/8 boys know everything there is to know about going Very fast
Old 05-11-2004 | 02:00 AM
Default RE: Pipes
That adamshowtime nows his stuff
Cheers guys ive gone with the Ofna pipe ill let you all know how we get on
Thanks to you all
Old 05-11-2004 | 03:38 AM
Banned
Default RE: Pipes
Pros and cons again, I agree with Adam and Fourbolt for different reasons, mainly the material does make a difference, due to expansion rates mainly, as the RB is thicker it doesn't expand as much and is a bit stronger against dents and such. But With the Mod carried out the the manifold of the OFNA, it is a far more responsive pipe than the RB for less bux, but you will be bending it back into shap more often (if you do it while it's still warm it's better). So IMO balancing out the 2 sides and taking price into consideration, I would go for the OFNA, But if you go to www.microtechracing.com and look at the pipes section then there are some nice RD Logics jobies that just whoop the ass off of both of them. I run all 3 pipes in question on various buggies and find the RD to be the best and surprisingly cheapest.
N.B. If www.microtechracing.com gives you a page unavailable error. Clear your cookies and temp files. Then try again.
Old 05-11-2004 | 06:22 AM
Default RE: Pipes
Cool site but as stated above the Ofna i went with so ill see and let others know
Cheers to you all
Old 05-11-2004 | 01:02 PM
sh0wtime's Avatar
Default RE: Pipes
its nice when we agree on things Alex
Old 05-11-2004 | 06:35 PM
theShark's Avatar
Default RE: Pipes
some buddies who run motorcross babble about pipes all the time....supposedly resonance and heat retention is a big factor in two strokes....I'm going by a friend who makes pipes and try to make a pipe out of the same steel they use.
