RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
head shim
Old 05-11-2004 | 11:50 PM
joes75's Avatar
Default head shim
Does anyone know how many head shims should be on the FORCE .26 from the factory? I only see 1 under mine, and I think it should have at least 2 if Im not mistaken. thanks
Old 05-12-2004 | 12:23 AM
Default RE: head shim
You should have two. They are really thin and almost look like one..
Old 05-12-2004 | 12:32 AM
joes75's Avatar
Ok, Im gonna check it again tomorow. Now if I only have one shim, how would the engine perform? Because I have noticed the temps are a little bit high. thanks for the reply
Old 05-12-2004 | 12:38 AM
The less shims you have the more compression you will have. Usually when i have a feeling that the engine is about to die and i feel a loss in compression i take out a shim to keep the engine running longer.
Steve
