RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
eb4 starter box problems
Old 07-10-2004 | 12:32 PM
Default eb4 starter box problems
lo all
i have just brought a team magic X5 starter box and i cant seem to figure out how its
suposed to reach the main gear. the main gear is in the center of the car the driving
wheel only goes to either side. am i not seeing something?
Old 07-10-2004 | 03:30 PM
Default RE: eb4 starter box problems
It isn't supposed to go to the main gear. It's supposed to bump against the fly wheel atached to the engine.
Old 07-10-2004 | 04:51 PM
Thats what i was doing wrong LMAO
Old 07-10-2004 | 05:21 PM
samcim's Avatar
Old 07-11-2004 | 11:11 AM
thing is the flywheel is too high inside the chasis for the starter wheel to rub against it.
i have the eb4-s2 pro rtr kit. is it posible that i need a bigger flywheel?
getting on my nerves now, i just wanna use my new starter box! sob[]
Old 07-11-2004 | 11:41 AM
If you have the TT engine with pull start you carnt use a starter box without removing the pull start and using smaller engine mounts......and as for getting a bigger flywheel it would hit the centre diff case.
Hope that answers your questions
Old 07-11-2004 | 11:48 AM
samcim's Avatar
try http://www.maxbashing.com there all from the UK there and alot use this starter box
Old 07-11-2004 | 12:00 PM
Well i could get the wheel up on my Hyper 7 Pro but it was kinda hard to match it up. I filed the hole open about 5 mm on each side and angled it out on each side so the wheel fits in their with no problem. Ask if you want pics... ill be glad to help you
Old 07-11-2004 | 03:02 PM
As some one already said you need the non-rtr engine mounts. The rtr engine mounts raise the engine so the pull-start will fit. Get some fancy red anodized ones off of ebay. Or maybe the flywheel on the pullstart motor is smaller?
