Not a BEC connector
I ordered a Rx battery from my H7 and its by Ofna so I assumed it would be compatible with my H7 but its not.It doesnt have a BEC connector like the switch does.What should I do?If I put a bec connector on I can't charge it.Unless I put the BEC connector and the other one but i dont want risk messing up the battery.Is there a different switch I can buy?
I found one that is a Airtronics one but it has one thing for the battery then 2 things coming out of it as if they would go in the receiver.Can someone direct me towards the proper kind.
if you mean the connector on the switch is too small and only has two pins, whereas the battery has enough room for three pins but only uses two just cut a slit in the connector to the switch i.e physically attached to the switch and slot in your new battery
[8D]
[8D]
Banned
That 3rd connector you described is a charging line. As in you dont need to remove the battery, you just plug the charger into the third line.
one of them sound useful
. with one of those you could stick the third connector out the top, seal it off and never need to open that battery box again, next time you open it you may find advanced micro-organisms!!!!
I meant the connector for the battery on the switch is one where it needs the red small one with 2 humps.I have the one with enough for 3 but only use 2.I'm going to buy one of those switches with the charge line too but the connectors are blue and my battery connector is black.Are the incompatible?
shouldn't be i've got red and black connectors on mine, i'd wait for grahama's input on that though, he is very wise on such subjects, check my sig
