RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
$250 for an engine, please help
Old 10-23-2004 | 08:57 AM
Default RE: $250 for an engine, please help
ORIGINAL: hyperpmp1
say what you will but THE BEARINGS DO NOT SUCK! and the JP1 is the way to go and it lets the motor run just as good if not BETTER! im sorry but you are just wasting this guys money. 3 gal on my V and 2 others at the track are at the 4gal mark and have not had 1 prob w/ anything. just like any other motor if you take care of it properly it will last a LONG time. this is one of the best motors in the market today and i dont see or hear ANY issues w/ it .
Check out the OS Thread on S-Grid and you will see a TON of postings about the OS Bearing failures.
Old 10-23-2004 | 09:10 AM
i personally have never had a bearing failure on any OS engine..VZB, Vspecs, .18's...but when i rebuild them..i do replace the os bearings with a rb c5 bearing..rear bearing only though...still use OS front..
and the 2050 is the only pipe to go with...the only other pipe i would run is a 086....as it seems to yield same performance..but has slighly less run time
Old 10-23-2004 | 09:35 AM
Can someone post a link to the s-grid forum.
Old 10-23-2004 | 09:51 AM
www.sgrid.com
goto offroad conference 2004
Old 10-23-2004 | 10:05 AM
Old 10-23-2004 | 02:00 PM
  #31
A co racer and I bought the OS vz-r at the same time. We both have about the same amount of fuel thru the engine. His bearings went bad. Come to fine out that he was not putting after run oil.
Old 10-23-2004 | 02:05 PM
  #32
A co racer and I bought the OS vz-r at the same time. We both have about same amount of fuel thru the engines. His bearings went bad. Come to fine out that he was not using after run oil.
Old 10-23-2004 | 02:59 PM
  #33
any place to get a the T-2050 pipe other than rc-mushroom? its out of stock, and expensive. any place in stock and cheaper?
Old 10-23-2004 | 03:23 PM
  #34
They are about 110-135 anywhere you look. I got mine for $40 in mint condition used off of ebay.
