hyper7 engine probs
how do i take the flywheel off of my engine so i can get to the ball bearing because it seems like u need a special tool
thanx
joe
thanx
joe
i used this link
http://www.twf8.ws/new/tech/clutch/clutches-index.html
after i had too that nut off just hit the bk of fly wheel hard then it should just come off
it tells you how to do every thing on the link i told you
hold the fly wheel with a flywheel Wrench or some thing like plyers or a towel will do then use the Cross Wrench that you get with a new buggy as one of the ends fits
like this http://www.twf8.ws/new/tech/tip/brea...d-clean014.jpg
browney all done now but the heat sink screws are worn or it might be my tools but im sure it isnt how do i get them out
