Wasp .28 factory settings
Could anyone tell me the factory settings on the low, mid, and hi needles? I'm having the hardest time breaking in this engine. I read alot of post on the engine and it seems to be a very debatable engine. Also, it seems I have alot of back compression coming from the engine and makes my gas lid pop open and spray fuel everywhere. Anything I can do to fix this? Tks.
RE: Wasp .28 factory settings
HuH? Wow. Try a new gas tank- and make sure your fuel tubes are connected to the right nipples- they might be crossed.
As for breaking it in- richen everything up a turn or two- and then lean out in 1/8th or 1/4 turns until it fires. And don't forget to heat it up with a heat gun to about 200 degrees before starting every time.
