RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
engine preheating
Old 01-25-2005 | 05:57 AM
o.s 21vspec's Avatar
Default engine preheating
can you all give me your opinions on if it would be beneficial to pre heat your engines to almost running tempreture before starting.thanks
Old 01-25-2005 | 06:25 AM
Default RE: engine preheating
Pre-heating process will reduce the piston and cylinder wearing and the stress to the conrod in certain extend compared with just starting engine at the ambient tempreture, which in turn will enhance engine life.
Old 01-25-2005 | 08:17 AM
MassiveMods's Avatar
theres not much in it, id be inclined to start the engine and let it warm up a good minute before revving it more that 1/4 throttle.. it will take an engine about 2 laps to warm up..
Old 01-25-2005 | 09:41 AM
But when the engine is completely new, I guess it should be preheated? Or is this not necessary?
Old 01-25-2005 | 09:48 AM
scale only 4 me's Avatar
My Feedback: (158)
I think yes,, especially when it's new,,,it's very helpful during the break in stage,,,once it has about a 1/2 gallon of fuel through it it doesn't really need to be preheated any more
Old 01-25-2005 | 10:54 AM
cool thanks for the replys.
im currently workng on a engine preheater it will run on 12v dc have a thermostatic control to keep it at about 90 to 100c and will be adjustable to in size and temp.
just hope it works
Old 01-25-2005 | 01:49 PM
is this a personal or commercial venture
Old 01-25-2005 | 03:22 PM
dont know yet i will see how it goes
Old 01-25-2005 | 03:45 PM
ORIGINAL: o.s 21vspec
just hope it works
Or your mommy's blowdryer will do the trick.
Old 01-25-2005 | 04:25 PM
dont think my mums got a hair dryer shes that old,lol
its for when your out at trackside
Old 01-25-2005 | 05:29 PM
Aerobirdbrain's Avatar
Trinity has some tire warmers that would fit really good around the head of the engine; I'm not sure if you can buy them individually or if you have to go with a set of four.
Old 01-25-2005 | 06:00 PM
fhm101's Avatar
I always preheat new engines during break in. As much to avoid wear and tear on my starter box as on the piston and sleeve assembly.
Old 01-25-2005 | 07:44 PM
Yub, yub, cmdr!'s Avatar
I'm thinking that maybe you could use a very simple assembly of these little semiconductor units that, if voltage is applied, it sends all the heat to one side. So technically you could heat an engine with those.
