RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
Problems with universals
Old 02-27-2005 | 06:19 PM
Default Problems with universals
Hey guys, On my kyosho mp 7.5 kanai 2 two of my universals are popping out of the universals when they are the correct size I dunno why its happening I tried to see why but I haven't found the problem. The ones that are popping out is the front left universal and the rear right universal. Please help.
Thnx Hpi_mt2
Old 02-27-2005 | 06:39 PM
Default RE: Problems with universals
I will try to check my camber and see if it helps
Old 03-12-2005 | 01:31 PM
Guys im still having problems with my universal popping out and i dont really want to miss the race tommorow so if you would please help me out as soon as possible i would appreciate it thanks
Old 03-12-2005 | 03:17 PM
Chex's Avatar
is there a chance you've mixed them up? i.e front uni on back and vice versa
Old 03-12-2005 | 07:25 PM
No they are the correct universals in them I've switched all of them out the right side has no problems but the left does i ahve no clue what is happening. I've tried everything. And guys i bought this car used and the previous owner told me that the a arms were a little loose could that have anything to do with it?
Old 03-12-2005 | 07:44 PM
Chex's Avatar
i havent heard of this problem on a k2 before..and im not sure what loose a arms are....
you could try limiting suspension travel for a temporary fix to get you through the race.....
Old 03-12-2005 | 07:46 PM
MassiveMods's Avatar
you will get this with flex, have a look at the screws that hold in the hinge pins. ie the hinge pin holders.. they tend to get loose, i had a race last tuesday and my front uni popped out 2 times, i replaced the hinge pin holder and no more problems.. also pull your castor in to shorten the uni travel.. Um what elce ..... thats all i can think of, good luck
Sorry forgot to mention it was the lower hinge pin holder... check both though
Old 03-12-2005 | 08:06 PM
what do you mean by castor thats the only thing i dont know sorry.[] And plus when i add more negative camber it will stay in but thats not really good for a buggy right?
Old 03-12-2005 | 08:09 PM
and also when i want to limit the shock travel if that is necessary should i make it to where the a arms are about the same position as the chassis when there compressed?
Old 03-12-2005 | 08:56 PM
Chex's Avatar
yea - so theyre about parallel to the ground....but it sounds like massivemods has had this problem - Id go with the hinge pins holder advice as these hold in the a arms and could be what the previous owner meant by loose a arms
Old 03-12-2005 | 09:27 PM
Aren't the hinge pin holders the screws that you can tighten so the other side of the a arm the screw sticks out? Well if thats it im stumped i have no idea whats wrong.
Old 03-12-2005 | 09:54 PM
can anyone pm me so we can chat on msn or aol?[&o]
Old 03-13-2005 | 03:10 AM
sorry i meant cambe, i always get those two wrong.. id say 2 deg neg camber is ok.. loads of people use lots of neg camber for off road.. helps steering and handling..
The hinge pin holders are the things that the hinge pins go into ... these are mounted to the diff housing, the two screws that hold it into the diff housing need to be tight.. check those..
Old 03-13-2005 | 09:32 AM
okay is neg 4 camber okay?
Old 03-13-2005 | 10:54 AM
scale only 4 me's Avatar
My Feedback: (158)
-4 is OK If you like going through tires fast
-1 to -2 max
Also check the bearings in the diff cases and the condition of out drives hubs
the outdrive hubs get worn and rounded off with age, that coupled with a loose bearings in the diff cases can make for a very sloppy out drive, that might adding to the problem as well
There was a guy at the track (SV) yesturday complaining about Unis popping out, was that you?
Old 03-13-2005 | 10:14 PM
Oh okay no i dont live in california so that wasn't me. Im thinking i should just replace the a arms and the diff housing and bearings and the outdrives which are the knuckles right?. To just get it back to good shape. Or should i just go to the hobby shop if i dont know whats wrong.
