Hyper .21 pullstart question
NC
*** i didnt even get the motor started and the recoil snapped off in my hand!! i set the carb to the specified factory settings for break in it fired once then quit then finnally the recoil came off in my hand! [:@] thing was a bear to pull over to begin with so i dont think it was a hydrolock problem. i have this motor in a savage .25 truck DO THEY MAKE A ROTO START THAT WILL WORK WITH THIS MOTOR? please help. im so sick of having problems with my pullstarts on all my motors.
There isn't a roto start for the Hyper 8 Port, but you can modify one to fit, if you're really into dremeling. I modified one to work on my hyper and works ok, really just ok. I'm in the market for a starter box now.......
Banned
The turbofans in the Hyper engines do not stand up well to tigerdives or rotostarts. Your better off with the pull start, BUT LEAVE THE PLUG LOOSE WHEN YOU ARE DOING BRAKE IN. Then once it's fired up for 10 secs then you can tighten it.
