RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
Shock Setup
Old 05-02-2005 | 06:57 PM
Default Shock Setup
I've noticed that many people run heavier shock oil in the front shocks than they do in the rear shocks. What are the handling benefits of this?
Old 05-03-2005 | 06:13 PM
Default RE: Shock Setup
Is it just because the pros do it? If so, it's ok to admit that. We're in a safe place here. The reason I ask is because I don't see the benefits. Any guesses?
Old 05-04-2005 | 12:48 AM
SManMTB's Avatar
Looks like you found the answer.
Old 05-04-2005 | 06:19 PM
After thinking about it for a while I think I may have answered my own question. The heavier weight oil in the front shocks probably reduces the front end roll in the corners which would plant the frond end better and thus improve high speed cornering.
Old 05-05-2005 | 01:27 AM
Foxy's Avatar
You'd think so, wouldn't you, but it's not true. The only part that can affect body roll is the anti-roll bar. The reason that more damping and stiffer springs provides better turn in is simply due to the increased stiffness in the front end, which of course then provides it's own problems on bumpy tracks. As with all aspects of suspension setup, it's about finding a balance that works for your style. If you haven't seen this, it's a flippin amazing article. I thought I was pretty hot at setting up chassis and suspension (for on road anyway), but I learned a lot from these articles.
http://users.pandora.be/elvo/c1/index.htm
The first chapter is tyres as per the link, then it moves onto suspension settings, the 'next page' button is at the bottom. It has a clear explanation (as long as you have a good grasp of mathematics) of every aspect of suspension setup. The aerodynamics section is also particularly interesting...
Old 05-05-2005 | 01:35 AM
I use slightly heavier oil in the front to slow down weight transfer in the front so as to smooth ou the the turn in and so the back dosen't hook. it also launches the car better and with more nose up over jumps
Old 05-05-2005 | 07:39 AM
wow - great stuff foxy42 -- where did you find this info? It is very well written - almost like a thesis.
Old 05-05-2005 | 07:45 AM
Foxy's Avatar
It was mentioned in another post on this forum some time ago, I forget by who...thanks, whoever it was!
Old 05-05-2005 | 08:19 AM
Galifrey's Avatar
foxy42
how can you forget it was me...
http://users.pandora.be/elvo/ is the correct link with sidebar
Old 05-05-2005 | 08:36 AM
Foxy's Avatar
Thanks again mate....
Old 05-05-2005 | 09:03 AM
MassiveMods's Avatar
and who did you get it from eh ... lol
Old 05-05-2005 | 09:47 AM
Galifrey's Avatar
ORIGINAL: MassiveMods
Its called a search engine, something most people on this site aren't familiar with...
