New buggy
My Feedback: (15)
IL
I picked up a cheap RR Lightning and I have a few questions?????
I tried to put my Ofna JP1 pipe on it and the header is to big. I think the engine is a .21?
Any idea why the header is too big to fit on the engine. is this common
also, Are there any bodies available to fit the Lightning 1? is it the same as the 2?
Any other info will be helpful also...
Like the difference between the 1 and 2...stuff like that
thanks
thanks
IL
The engine is most likely a .26 It's a common engine in most Hot Bodies cars/trucks. I'm afraid I don't know much about what size header you can use. Their website has a bunch of new pipes and things, maybe you can pick one up there?
NotMe
NotMe
My Feedback: (15)
IL
This is the Lightning RTR 1
It has the Hotbodies 3.5 which I believe is a .21
I have an extra Mach 26 from my LST. Will this bolt right in? Will the stock clutch and things work on this.
