need help on charging battery for starter box
My Feedback: (13)
idk how will i set my charger..can i use the duratraxx chargers?if i can use it how many MAH ahould i set it ..i kno for amps i need to set it to 2amps..not sure about the MAH part..can someone help me ?
AZ
What kind of starter box is it? And what kind of battery?
In my ofna universal I just got the Hobico 12v battery and the Hobico charger.
All i use is a 12 volt battery charger to charge my gell cell for my starter box. Clip on the leads (+) & (-) and charger it for 4 - 6 hours. Always works for me.
My Feedback: (-1)
CA
bad boy: no... you cant use the intellipeak to charge that battery... The big battery you have is a 12 volt lead acid gel cell battery and the intellipeak doesn't charge lead acid, only nicd and nimh...
get a 12v wall charger at about 1 amp
AZ
This is what you need:
http://www2.towerhobbies.com/cgi-bin...&I=LXL353&P=ML
Only 10.99 your lhs should have one too.
