RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
23mm Adapters
Old 07-21-2005 | 10:29 AM
Default 23mm Adapters
How do you put them on? They are not threaded.
Old 07-21-2005 | 10:52 AM
cemeb4dk's Avatar
Default RE: 23mm Adapters
They are held on by the wheel nut.
Old 07-21-2005 | 11:09 AM
NOt how do you put the wheel on. How do you put the adapter in. YOu put the pin in, then usally you screw in the two set screws to lock the pin, however the set screw holes are not threaded.
Old 07-21-2005 | 11:12 AM
cemeb4dk's Avatar
What are you putting these on, you can not use the typical buggy cva with the set screw that screws into the pin. They are used on MT axle where the are threaded on the outside and the pin is external.
Old 07-21-2005 | 03:48 PM
ThunderbirdJunkie's Avatar
ORIGINAL: Seiki
according to proline's site, you take off the stock hex adaptor, and put the 23mm adaptor on like you were installing a wheel.
just fit it over the axle, and use the stock wheelnut to secure it, THEN you put the 23mm wheel on, THEN put the 23mm wheelnut on.
that help?
*EDIT*
THESE ARE FOR MONSTER TRUCKS THAT USE A 14MM HEX, NOT YOUR 1/8 BUGGY
