Which Motor?
Which Motor?
What's up guys. I need a engine for my 8th scale that I will start racing soon.
RB WS7-2 $309.99
RB1004-WS7
Novarossi 21 P5 Long Stroke Buggy $279.99
NVRX21P5
Rex PR421B Buggy $329.99
REXPR421B
Can't decide What do you guys think?
RB WS7-2 $309.99
RB1004-WS7
NVRX21P5
REXPR421B
IL
RE: Which Motor?
depends on the size track as well. i go to a lot of them and ive found the P5 to be a great motor. it really does well in the short sections and the long right at the end of a strait im topped out and ready for the next corner. the WS7 i have had as well and it is easier to drive for a beginner. the bottom end is not so harsh (balistic) it is smoother. the ws711 is more of a top end but w/ the right pipe it can pull at the bottom as well. the 421 is a bit harder to tune day to day. the P5 imo is the best and holds its tune very well. i have the P5 & P5X the X is not so crazy on bottom but its still a beast all around. it has the new 2 needle carb- 1 less thing to worry about...
RE: Which Motor?
I agree with you based on everything I've read about the P5x. I'm a fan of 2 needle carbs. I'm an ok tuner but the less stress the better So the P5x is the 2 needle? the P5 is a 3 needle?
IL
RE: Which Motor?
yes it is! the x model is this yrs. the reg p5 is last yrs. right out of the box they fire right up and run. very easy to break in. at least the 4 p5's ive broke in were.
RE: Which Motor?
Awesome. Thank you for the clarification! Gonna buy one today! I have the JP1, Jp2 and 086 pipe. Short track jp1? big track jp2 or 086 depending on the straightaway? What do you think? does my logic make sense?
RE: Which Motor?
If i was you i would buy a modded p5, they are insane. I recommend eb mods, get a p5 from them and break it in slowly. After you get it broke in you will not believe the power, and then after you get a gallon or so through it, it settles in and goes even faster. I swear to you a modded p5, is by far the baddest engine on the planet. Hands down without a doubt. line them up and pack a lunch son, these thing make a buggy fly.
IL
RE: Which Motor?
really no need for a modded P5??? why mess with something thats already more than enough power. and some mods are harder to tune. as for the pipes - JP2 will prob be the best bet. the p5 has so much bottom the jp2 makes it run perfect and you will get lees wheel spin = faster laps and better fuel consumption.
IL
RE: Which Motor?
just so EVERYONE knows !!! i have both and have run them (p5 & p5x) in my car back to back in the same hour. the new one is not that much different at all. you would have to be a PRO to tell the diff. believe me it is still a stump puller........and then some! its more power than most can handle on the track. i switched motors 3 times just to see how much the new one was changed. both w/ the same clutch ,and it was hardly noticeable at all.
