odonnell plugs and fuel
well the ttr s3 is ready to start i will pick up fuel wed. of this week at my LHS i chose the cold odonnell #99 plug and was thinking of trying their fuel in 30% but what is the oil content of this stuff and would like some feed back on this fuel i would also like to know if there is a glow ignighter in the world that locks down to an odonnell plug. LOL. when its broke in i will give a reveiw of this new collari inotek s380 that i have mounted in this pig along with the vantage raceing carbon pipe.
RE: odonnell plugs and fuel
im pretty sure O'donnell race fuel 30% has 8-9% oil. the more the percentage of oil content the hotter it will run by the way. i never run fuel with more than 11% oil
Depends on what Odonnel fuel you go with, there are a couple of different blends so I would check there
website or call and ask. As far as plugs I always run as hot a plug as I can get away with. Colder plugs will
run a leaner mixture and as a result make slightly more power and get a tad better run time but a hotter
plug will idle better and have a wider tuning window. I dont think I have ever run a Cold plug in anything,
generaly I stay with a Med or hot so either a 97 or 77. The spring clamp ignitors will work fine on a OD plug.
