2 speed in mayhem.
FL
RE: 2 speed in mayhem.
slow down there trigger..... No response after 12 hours is normal sometimes, repeating the question doesn't speed it along much. The right people who have the answer just haven't read this one yet. Then again, it may be something no one has tried and you may just have to find out yourself.
VA
Measure the ofna 2 speed from hight, width, and lenth to see if it fits also check the chassis mounts. It it matchs the single speed in the mayhem then it will. Are you just bashing? If not 2 speeds only screw you up in 1/8 buggy racing. Hit 2nd gear on a jump and you go front end high also makes you squirly when it shifts. Or it gets stuck in second and you lose your acceleration. You also have no center diff so you have locked 4wd so theres not as much front tire pull out of the corners giving you understeer when your on the throttle. Just a few warnings if you plan on racing with it.
