Hot Bodies Lighning 2 Roto Start problems
My cars been starting fine but i went to start it up today and it wasnt having any of it.
The roto start spins but the engine doesnt turn over, remove the glow plug and it will. I know its not the one way bearing as it has has 2 different ones in it, 1 new and one that is working fine on my mates
RE: Hot Bodies Lighning 2 Roto Start problems
probably because you flooded the engine, take the plug off, turn the buggy over so that the engine is facing the ground(or you can just lean the buggy to on side so the fuel does not get on your buggy) and turn the engine over with the roto start for a few seconds untill all the extra fuel is out of the combustion chamber. put the plug back on and pull the transmitter throttle back half way and start it.. it should fire right up
