engine probs
engine probs
hi i have just bought a seconf dhand hyper 7 engine and it has a new piston and liner fitted but when i turn the fly wheel once or twice it wont go any further every thing is their and has good combresion and i was wondering if anybody knows what is wong
i also havent even tried starting it incase i break any thing
RE: engine probs
If it's a new piston and liner it could just be high compression. Try it without the glow plug in and see if it turns a little easier. If it does reset the needles to break-in settings and do a complete run in ot heat cycle.
Ian F.
ps It's sometimes easier to start a high compression engine with the glow plug a little loose. Then as soon as it starts tighten it up.
Ian F.
RE: engine probs
i have taken out the glow plug and the head of the engine and it is still hard to turn its good for a couple of turns then it gets impossible to turn
RE: engine probs
Sounds like a strip down job. Make sure all the shims are in place and that the liner is in the correct way. Re-build with plenty of oil and see what happens.
Ian.
Ian.
