mbx5 hinge pins
WI
mbx5 hinge pins
are they longer or shorter than on the kyosho 777's
can anyone measure them for me
I want to use the inside lower screw pins on my buggy if the would fit
the K speed ones are hard to find right now
thanks ,Joe
thanks ,Joe
WI
RE: mbx5 hinge pins
I wasjust wondering the length compared to the 777
I can get mugan inner screw pins from my hobby shop right now with my discount but need to know if they will fit my car
I know the diameter is the same just don't know what the length is
IL
RE: mbx5 hinge pins
JOE i just measured the stock ones are 63mm on my caliper the k-factory ones are just a tad longer for the nut to screw on. 71 mm is pretty close the k-factory ones are on the car and it was hard to measure but thats d@mm close. hope this helps....PETE
WI
RE: mbx5 hinge pins
thanks for checking Pete
too short
guess I will have to wait for the k speed ones to get back in stock
at least you didn't tell me to get a different car
if I knew that great pains was going to drop kyosho i proubably would have went for a m car
too short
