tire advice
GA
tire advice
I am looking to put some MT tires on my Ofna LX buggy for bashing mostly on grass, pavement, and occasional baseball field. Any suggestions on tires? I was wondering if I could get away with using Proline road rage on this range of surfaces? Any recommendations appreciated.
NJ
RE: tire advice
Road rages would be fun on a baseball diamond. The car will slide around alot. They will go through grass but prolly not too well unless its cut really short. If your mostly on asphalt...go with them. I would want some sort of knobby for grass and general bashing. Whats wrong with the buggy tires? Your going to have to re-gear it for larger tires.
GA
RE: tire advice
I want to put MT tires on my buggy to gain a little more ground clearance for driving in grass. However, I have heard that if you put on low-profile MT tires like the Panther Komodo on MT rims than you don't need to change the gearing...so I think this might be a good compromise.
