the force .25 and .26 crank shafts the same
VA
RE: the force .25 and .26 crank shafts the same
First I'd like to ask how you broke a crankshaft? You can just take that one out and set it along side of a .26 shaft and see how it matchs... but I think there the same.
i was running my buggy that someone traded me and im tunign the engine. i had it running nice and all of a sudden i hear snap. i took apart the engine and found out the that part were the con rod attaches to the shaft snapped(the stub sticking out of the crank shaft).
My Feedback: (8)
MI
I will second that they are the same. The only difference between the Force 25 and the Force 26 are as follows:
[-]Piston
[-]Sleeve
[-]Head Button
[-]Head Shims
[-]Cooling Head
everthing else is the same.
[-]Piston
[-]Sleeve
[-]Head Button
[-]Head Shims
[-]Cooling Head
