Hyper 7 engine attachment
Hi there,
I was "flying" my hyper 7 yesterday but once again the engine rotated to the left and the clutch-shoe got killed -again- just like the big wheel.
I am not able to properly attach the engine to the base-plate.
I am curious if there is someone who can give me advise. I used all power[sm=punching.gif] knowledge[sm=bananahead.gif]and
respect[sm=RAINFRO.gif] to keep the engine in place but .....
many thanks
many thanks
RE: Hyper 7 engine attachment
Maybe you just need a model plane.
In all seriousness, go back to your manual, build your car correctly and use threadlock.. Not a lot else to say bruv'...
If you already used threadlock on the screws then try some on the plate and base.It might help a little.OR get a new plate if something is wrong with the one you have now!
what plate you're talking about ? is it engine mount lower plate or flywheel ?
i think you shouldn;t use any thread lock for engine mount (especially the red one, god it'll kill you).
if you keep breaking your clutch shoe, try to use MBX-5 clutch shoes and its spring (with OFNA clutch bell).
i use them now and it work great.
and if you keep loosening your engine mount screw,may be you need a new one (engine mount).
thx
thx
Thanks for all the good advise!!
Uh I think you got a point here. I have been releasing the screws several times now. Maybe I need new one!!
For the other question:
I am talking about the bottomplate not the enginemount.
And uh why is this red stuff going to kill me??
thanks
thanks
AZ
The Red loctite is high strength. Use this only on screws/bolts you do not want to remove. This is a permanent thread locker, that loctite says requires heat to remove. So, don't use it on any part of your car you don't want to take a torch to (which rules out most screws).
