OS RG .21???
#126
RE: OS RG .21???
I kept most of the buggies I've tried up til 2 months ago....I sold My MBX-5 and Mayhem......I still have 2 fully functioning buggies to play w/ now......and I won't go into the whole T-maxx upgraded beyond belief so I can't sell it now story.....it's hard to let go of something you spent time tweaking and seting up justright.....truth is you know once you get a top end buggy you won't want to go back and drive your OFNA again.....unless it's a Jammin of course...
#127
RE: OS RG .21???
It started out as a really good deal on one , then another guy had one for sale a week later with a whole b*ttload of spare parts ($200 worth) and a good picco .26 for $250 , then of course there`s ebay , so I ended up with enough parts for 3 buggies ! That`s why I`m still runnin` the Pro 1 cuz I`ll never run out of spare parts . Plus the thing still handles good and is built like a tank .
#129
AZ
RE: OS RG .21???
Superlative,
Very nice!! Good job on your last win!
Is that an RG? If so, good choice on the pipe 086 (I alomost got that one, but got JP-2 instead) and I knoticed you even have an RPM adaptor. How's that working? I haven't tried one of those yet.
#131
AZ
RE: OS RG .21???
Well, I tried a little moding on my RG this past week.
After my last race the air filter fell off of the engine after the 6 minutes mark and didn't run to well and sucked in dirt. So as I took it apart to clean it up and noticed the piston and sleeve was still good.
So as I cleaned it out I got the bug to try to mod it since I have a brand new engine that still needs to be broken in.
I used a dremel tool with a carbide cutting bit, various grinding stones, rubber polishers and cloth polish bits with compound.
Well I got to tune it a bit today. After getting the HSN dialed in I finally got the LSN dialed after chasing the tune for a bit.
Once it was all figured out and running, I have to say I think I notice a big difference! IT seems to keep Revving a bit longer.
The true test will come Sunday and I get to run against other buggies and then I can gauge how much of a difference there is.
#132
RE: OS RG .21???
ORIGINAL: J_Bone
Can I say it???
Can I?
HUH????
#135
OK
RE: OS RG .21???
Just got it tuned out pretty decent. 11 minute run time on a tank if I push it abit. It has plenty of smooth bottom power, but it revs out too quick. I know its characteristic of the engine....but I might try a 14T clutch bell to see if I can get a bit more top out of it.
On the straight compared to my Hyper21 it would get pulled a little starting at the pit entrance...but I think I can make it work
#136
RE: OS RG .21???
an OS runs like arse on a 13t CB...even stock.....14t AT LEAST....try 15 if you have a large straight on your track too.....it does eat the bottom end a lil more than I like but man it will fly when it can stretch it's legs...
#137
AZ
RE: OS RG .21???
ORIGINAL: plaidfish
Can I say it???
Can I?
HUH????
ORIGINAL: J_Bone
Can I say it???
Can I?
HUH????
For my track......
I did the 14T clutch bell and it didn't come out of the corners good enough. I first tried the 14T CB while driving by myself on the track. It seemed good and I was digging it. Then I ran with a few guys and they were pulling from the get go and I didn't like it. By the time I got down the strait it was to late to make up any ground.
Then when I switched to a JP-2 pipe I noticed a big difference. Then with the mod it did seem to help a bit more and give it more fuel mileage. I was neck and neck with some P5's from corner to corner.
Well, I TQ'ed and won the "A" main so I fell good about how it's setup and running considering I beat a lot of $250 and above engines along the way.
Now the 14T clutchbell probably will work on other tracks....[:-]
#138
RE: OS RG .21???
Congrats on the win man.....I wish I could win an A main....I have the luck of running against a few pro drivers at my track.....it makes for some good races but I can't get into the top 3 even against these guys....kindof a real bummer sometimes when it's a whole A main of real seasoned drivers and me...I know where I'm coming in LOL.....
do yo urun a real tight track???
Not knocking your ability but the RG should snatch that 14t CB real quick.....
also what clutch setup??? with th RG i use a .95 and aluminum lightened shoes.......real hot ***** hole shot setup for he RG...you really can't use that on super high traction tracks but short of mud you shouldn't have that issue.....
#140
RE: OS RG .21???
I have a rg and a v-spec. I run the rg at local weekend races with a jp-1 and jp2----If the tracks are real tight I run the jp1-if the the tracks are big and open I run the jp2. The jp1 also works great with a 14cb on large tracks. For under 110.00 the rg is good motor.
#141
CA
RE: OS RG .21???
When mounting the exhaust adapter to the rg engine are you guys doing it metal to metal or are you using high temp silicone? I just got my engine new in box and noticed it had no gasket for that.
Rippin it up!
Rippin it up!
