Ofna Hyper 7 Pro Throttle linkage (and manual)
I just picked up a used Ofna Hyper 7 pro ($200Cdn, yoink!) Does anyone know the part numbers I need for the throttle and brake linkage? The only part of the linkage i have is the little bits that the ball cup would snap onto at the brake calipers.
Is there an assembly manual for the pro kit? Mine didn't come with one, and the only thing i can find on Ofna's site is the exploded views.
IA
RE: Ofna Hyper 7 Pro Throttle linkage (and manual)
I run a [link=http://www.dynamiterc.com/Products/Default.aspx?ProdID=DYN2568]Dynamite Throttle Linkage[/link] on my buggy and really like it. The thumbwheel adjustment wheels are very nice and makes it easy to adjust brake bias.
AZ
ORIGINAL: gerwen
http://www.twf8.ws/new/tech/car/hoba...per7index.html
ORIGINAL: kx250ryder
There are many different hyper models. This is instructions for a C-hub model. If you have PBS suspension, you could still use the below steps for most of the car, but you will need to use the exploded views for the PBS suspension building portion.
FL
87091 (Throttle rod set) 87092 (servo linkage rod set) 87087 (servo ball end set) 87088 (servo linkage set) 224037 (servo horn set)
