Hyper 21 cutting out
QC, CANADA
When I give it full throttle it dies? It runs fine until i pin it? I lean it out and it still does it yet the engine is running hot(220-240). How can I get the temp down and give it full throttle?
hi there i have had the same problem if you look for a thred need advise you will see some setings to try i am going to give it ago tomorowif you sort it will you let me know as it has been doing my head in i allted the high speed mixture and it was v better the post was on page 3 if you want to take a look
