RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
Engine replacement for Force .26
Old 11-15-2005 | 08:32 AM
My Feedback: (33)
Default Engine replacement for Force .26
I have a Ofna LX Ultra inb which I blew up the Force .26 engine.
What do you think of the following engine as a cost-effective replacement?
http://www.dynamiterc.com/Products/D...ProdID=DYN0888
Old 11-15-2005 | 03:59 PM
REVO_RACER's Avatar
Default RE: Engine replacement for Force .26
im about to get the same buggy if u find out please thll me
Old 11-15-2005 | 04:58 PM
i put a werks/picco .27 in mine and it screams.....throws rocks and dirt all over the place
Old 11-15-2005 | 06:25 PM
My Feedback: (33)
If you plan to get this buggy, be informed that the steering servo is very weak.
Old 11-15-2005 | 07:04 PM
MBX5T Maniac's Avatar
My Feedback: (-1)
http://www.horizonhobby.com/Shop/ByC...ProdID=SWK8085
that is the engine made for the sportwerks mayhem buggy. That one will fit for sure. The other one might not fit.
Old 11-15-2005 | 07:09 PM
There is no reason why it shouldn't fit. And it is much better to get an engine without a pullstart.
If you want it cheaper, then the OS RG without pullstart is only about 100$. I have that one in my LX Comp and it is a great engine.
But the Picco .26 or .27 gives a lot of power if you don't need it to be racelegal.
Old 11-15-2005 | 07:37 PM
My Feedback: (-1)
grrr. why did i put fit?? I meant that the crankshaft might be different length, and then it wouldn't work.
Yes, I've heard a lot of good things about the RG. and if you buy it from tower now w/out pullstart, you can save 10 dollars, putting the total down to 100 dollars.
Old 11-16-2005 | 02:27 PM
clone3's Avatar
Get the OS RG---That is a good motor---It has ample punch and runs strong on the top end. How could you go wrong for 100.00.
Old 11-18-2005 | 08:55 PM
what about a larger engine? http://www.ofna.com/eng-force-32.html
I'm about to get the violator. and want an insane amount of speed.....
what o.s. engines would be good.?.
