RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
Fail Safe?
Old 11-30-2005 | 11:51 AM
My Feedback: (33)
Default Fail Safe?
What is the purpose/advantage of a fail safe? Can't I just put a return spring on my throttle linkage and accomplish the same purpose?
Old 11-30-2005 | 11:57 AM
SManMTB's Avatar
Default RE: Fail Safe?
A return spring is better.
The failsafe is useless if your power connector gets disconnected, or your linkage breaks, or the batteries in your Tx dies.
Old 11-30-2005 | 03:00 PM
ORIGINAL: SManMTB
SManMTB I agree with you..this is the principal purpose of the fail safe. You can check the failsafe to work. Only disconect the power of the TX and you can see the car stop.
Old 11-30-2005 | 05:48 PM
dicko's Avatar
a failsafe will protect if you get interference, or go out of range, i run both failsafe & return spring, they're cheap insurance for an expensive buggy. the failsafes i use also kick in when the battery gets low, so it will cut in before you run out of power entirely. if the power is suddenly cut, the return spring kicks in.
Old 12-01-2005 | 09:13 AM
all I got to say
is
SPektrum is the way......
Old 12-01-2005 | 10:22 AM
SManMTB's Avatar
ORIGINAL: plaidfish
all I got to say
is
Yeah that spectrum really works well if your links or power switch breaks....
Old 12-01-2005 | 11:17 AM
RTS are just a PITA...I've taken to pretty much only running at the track or my favorite construction site.......if I did manage to break a linkage I know it's not going too far...might blow up but at least it won't get far..LOL....I hate the inline fail safes anyway...nothing but issues w/ digital servos.....kept shutting off for no reason.....and I don't use a power switch..just plug right into the Rx......limit your posibilities of failure through regular maintenance is what I do......
Old 12-01-2005 | 06:24 PM
ORIGINAL: plaidfish
all I got to say
is
[:'(][:'(][:'(] What you talking about? specttrum????...He ask failsafe.....chama [>:][>:][>:]
