what engine??
ive never actully had an os rg, but keep hearing good very good things about these mills, ask engrose he really knows everything about this motor hope this helps
AZ
The RG is what I run (for now). Its great at making low end power. If you have the extra $20.00, try the Sportwerks .26 (what I will be running). It has slightly less low end than an RG, but will murder it from mid to top. Both like the Jammin JP-2 pipe, and both (as well as most engines) like a 3 shoe aluminum clutch and 1.0 springs.
