Will thse 3 work toegether??
FL
Will a Super Brain 977 charger, a OFNA 1400 MAh NiMH Rx stick pack, and these [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXL332&P=M]Connectors[/link] work together. DONT PAY ATTENTION TO THE TZ CONNECTOR, I DONT WANT THAT BUT I COULDNT FIND THE RX ALONE.
[link=http://www.ofna.com/images/EL-10211-batt-BIG.jpg]RX pack[/link]
FL
You dont sound too sure of your self.... I know the connectors will work with the charger, but i heard there are different ypes of reciever pack connections,and i want to make sure the two will match up.
I have that exact pack and conections they do work together. However if you get a Spektrum DSM that TX jack is wired backwards and wont charge it.
Now looking in the picture the Super Brain has a Tamiya connector so the banana plugs wont work unless you go banana on the Super Brain.
I would just make one you can get the Tamiya Connectors in a kit so you can build them, its just 2 wires. I would make one with a female receiver and a female tamiya end on the same wire. That will work on the Super brain to charge a flat pack.
I have a triton charger and I only have banana jacks thats why the leads you posted work for me.
http://www2.towerhobbies.com/cgi-bin...?&I=LXH440&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LXGG99&P=7
AZ
The Super Brain 977 is two chargers in one case. Channel A has two terminals to accept banana jacks, Channel B is pre-wired for a Tamiya connector. See your other thread for my response to the connection question. Its probably going to work, but you may have to switch wire positions, or file down part of the connector.
