RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
Servo Question??
Old 03-03-2006 | 02:40 PM
Default Servo Question??
Whats a good servo and whats not? Can I know what kind of torque a servo has from the model it is? Are there different servos for steering and others for throttle? Thanks I appreciate your input.
Old 03-04-2006 | 12:28 PM
Default RE: Servo Question??
How much do you want to spend...high end airtronics $200.00 for both the 957 and 958 or low end two futabas for $70.00 3501 (I thtink is the number for the 120 oz .20 sec servo from futaba)
Old 03-04-2006 | 12:32 PM
It is the futaba S3305.....tower for $37.00 each . 124 oz/.20 sec transit time. Great servo more the money better quality then the hitec junk in the same price range.
Old 03-04-2006 | 01:13 PM
Super_Dave's Avatar
I run the S3305 and you can't break them. They are one of the if not the most reliable servo out there. They are slow and a little weak compaired to those high dollar digital servos but the digital servos are just overkill and wont let you go any faster. I race with the S3305 and its not giving me any disadvantage what so ever.
Old 03-04-2006 | 06:29 PM
Klaus448's Avatar
You run that servo as your steering servo Dave?
What's a good throttle/brake servo as well?
Old 03-06-2006 | 04:35 PM
but as far as torque is concerned, what is high and what is low? and what kind of torque should i be using for steering in a 1/8th buggy?
Old 03-06-2006 | 04:59 PM
SManMTB's Avatar
ORIGINAL: junz
>100 oz for steering is a decent rule of thumb.
Old 03-06-2006 | 06:39 PM
Super_Dave's Avatar
ORIGINAL: Klaus448
A run the S3305 on steering and throttle/brake. 100 oz of torque is just about what you want for steering and brake (you can go a little lower with the brakes like 80 oz but the brakes slip unless you keep them perfectly clean and dry). Those expencive digital servos are nice because there fast but the torque is flat out overkill. They don't help you go any faster either as long as your analog servos are decent and reliable (like the S3305).
