RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
OS RG in hyper problem
Old 03-07-2006 | 01:27 PM
Default OS RG in hyper problem
OK Guys,I'm installing on OS RG P (X) in a hyper TQ the problem is the flywheel does not clear the brake assembly. This may be because of the spacer added to get the recoil start clear of the chassis. Has anyone encountered this before and how is it solved?
Old 03-07-2006 | 02:51 PM
dcs
Default RE: OS RG in hyper problem
If you are running quad brakes, you need to get the purple flywheel in order to clear the brakes.
Old 03-07-2006 | 02:58 PM
Its not quad brakes its dual. its a basic TQ with RG (P) X. It will only fit at a slight angle and then its only a very small clearance between the flywheel and brake. I would prefer to get a good mesh and have everything straight.
Old 03-07-2006 | 05:55 PM
I had the same problem on my hyper 7 tq kit I has to take out the little sliver spacers they have you use for the screws on the brakes.. hope this helps..
