Spektrum Hook up???/
CA
When connecting the spektrum telemtry system how do you do it? The directions say to connect the telemetry module to the bat/tel slot.....so where does the battery go? They do not supply a y connector with the unit so can I connect the battery to the aux input on the battery?
CA
I found out the the battery goes to the aux input after the telemetry unit is connected to the battery slot on the reciever FYI. If you are running a PT you use a y connectoer to connect the PT and battery to the aux port.....nothing in the directions!!!!
