RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
flywheel problem
Old 04-02-2006 | 11:26 AM
Default flywheel problem
My new hyper 7 pcr has just arrived and i haven't started it yet because i'm waiting for my friend to come round and help me. I got told that when you break in the engine you should put the piston at bottom dead center after running but i tried turning my flywheel but it wont go round so i'm scared that when i start it, i wont be able to put it BDC afterwards. Is the silver wheel by the engine, sticking out under the chassis, the flywheel? Does anyone have any ideas? Thanks...
Old 04-02-2006 | 11:35 AM
Default RE: flywheel problem
Yes that is the flywheel. All new engines are hard to turn by hand and many times need to be preied with a screwdriver to get them off TDC where the "pinch" is.
Old 04-02-2006 | 11:58 AM
joes75's Avatar
Preheat your engine prior to starting it and loosen the glow plug a bit. After you shut the engine off, the flywheel will be much easier to put at BDC since the engine is hot.
