Digital Servo
Will Digital servos make a buzzing noise even if they are not under a load? A just upgraded my jammin buggy with 3pk converted to spektrum with futaba digital high torque servo. They buzz even when at center. Also, can you use a external fail safe with the spektrum system?
they are constantly finding there centre point,they are much more accurate that analog servos i know i will never go back after have a high end digital coreless servo
AZ
ORIGINAL: utmb_pa
What size battery pack do you all use? Do you use a fail safe with the spektrum built in fail safe?
