RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
Differential slipping
Old 07-29-2006 | 09:46 PM
Default Differential slipping
On my LX Comp I just installed a JP-1 pipe on it and I think my center differential is slipping. When I'm at a comlete stop and give the buggy full throttle the engine revs kinda high, but it accelerates really slow. I took the body off and watched the spur gear and clutch bell and tried acclerating and the spur and clutch bell are spinning quite fast so thats why I think its the diff. How would fix the differential?
Old 07-29-2006 | 11:00 PM
Default RE: Differential slipping
Run a thicker oil or just put oil in it. I sounds like it is dry.
Old 07-30-2006 | 12:18 AM
Hincappe's Avatar
maybe clutch slipping
Old 07-30-2006 | 07:33 AM
Revo Eater's Avatar
Yeah, either clutch or flywheel slipping.
Old 07-30-2006 | 08:52 AM
J_Bone's Avatar
Take apart you clutch and center diff and see whats wrong!
Are your brakes rubbing? How about the center axels, are they turning too?
Old 07-30-2006 | 09:11 AM
No its not the brakes. I'm thinking its the center diff going dry. I'll take it apart tonight to find out.
Old 07-30-2006 | 09:41 AM
I just took it apart and the diff is dry. My LHS is closed today so I cant get any diff fluid, but could I use some shock oil as a temporary lube? I have 30weight and 45 weight shock oil.
Old 07-30-2006 | 09:47 AM
if it was dry though wouldn't atleast the front or rear wheels be spinning fast. i would wait until you can get the right oil. also i would check anyway just for the heck of it.
Old 07-30-2006 | 09:57 AM
the front wheels were balooning.
Old 07-30-2006 | 10:00 AM
This is why I bought a LX comp was so I can learn how to fix things because I don't know much about how the three differential work. Then after I learn how to fix things I am planning on buying either a Hyper 8 or a Jammin CR Factory Team so I wouldn't screw them up.
Old 07-30-2006 | 11:43 AM
ORIGINAL: nabanta
oh ok. well even though it's not the problem i would still check the clutch for wear. u know one of those common maintance things.
Old 07-30-2006 | 05:42 PM
J_Bone's Avatar
Even with no diff oil, you should have ok acceleration. Something else is wrong if you get high rev's and slow acceleration. That's usually a clutch issue.
Old 07-30-2006 | 07:55 PM
Ok I'll check on that next
