dyeable wheels?
GA
I have an Ultra Comp 2. It came with the white spoked wheels which are plain looking. Does anyone know if they are dyeable? I just want to add some color to it and was hoping I did not need to buy new ones. Thanks in advance.
GA
a freind of dyed is wing black so i would say you could die your rims i am not for sure exactly how he did it but i know that he baked the dye in the wing using his oven.
MA
Its quite simple and your white nylon wheels are perfect. Just pick out the color you want, fill a pan up warm water, bring to a boil and submerge the rims completely. Be careful of the boiling water. If you are creative enough you can even do multi color. Heres what I have used in the past.
[link=http://www.ritdye.com/]Rit Dye[/link]
Don't boil with the rims or other plastic parts in there. It can deform them. I have 2 ways I do it. I have a old coffee maker that is perfect then for larger parts I have a old crock pot. These get hot but not too hot. They will not deform the parts. I have left wheels in them for a couple of days and never had a problem. I was able to dye 2 40 series wheels at a time in the crock pot and 8 2.2 rims at the same time. Leaving the parts in there for 24 hours or more will allow the dye to penetrate deep into the plastic. This is great because if you scratch the part it will still be dyed. One cool thing you can do is get high temp wax and melt it and paint patterns in the plastic. This works 2 ways. It sometimes keeps the total original color showing, but sometimes the dye will penetrate a little and be a little less dyed than the rest. When it works it is too cool. If it dosen't you just remove the wax with soap and real hot water and put it back in the dye and the effect will be covered and will leave no trace.
