Hyper 7 steering plate wobble???
I'm having trouble with the steering plate on my hyper 7.
It seems that i have excessive play on the front wheels and it's caused by the wobble on the steering plate with the two steering posts.And if you add the small servo horn play it's $%^#$#&!
In the picture i circled the two points that i have the problem.BUT i can't fix it.The screw passes through some bushings and these bushings with the screw wobble like crazy.
Anything i can do???
GA
you can put two small washers on each of the bolts and that will take some of the slack out but you wont it a little loose so the steering will be free.
