Hyper 7 servo horns help
WV
hey guyz, just wanted to noe can i put a 11kg servo on the throttle and steerin would anything happen to the servo horns thanks guyz and is there any other choice if there is a prob??
thanks
thanks
the plastic horns that came with my H7 used to flex... I replaced them with metal horns.
I run a losi 8ight now though.. plastic ones on that are fine with a 13.5kg steering servo
i run a 13kg mg servo on my throttle/brake setup, i've had no troubles with the plastic servo horns, just make sure you set the end point adjustments correctly on your controller and you'll have no problems.
Banned
You may not have that option if you have a cheap radio, If you have a more expensive one that has end-point, then just read the manual or tell us the model of TX.
