OFFICIAL HYPER 7 THREAD
#251
FL
RE: OFFICIAL HYPER 7 THREAD
did you see the edit i made, r these them??
[link=http://cgi.ebay.com/OFNA-87374-CNC-7075-Rear-PCR-Shock-Tower-Hyper-7_W0QQitemZ110070291873QQihZ001QQcategoryZ34063QQr dZ1QQssPageNameZWD1VQQcmdZViewItem]OFNA (#87374) CNC 7075 Rear PCR Shock Tower [/link]
[link=http://cgi.ebay.com/OFNA-87373-Alum-Front-Shock-Tower-for-PCR-Hyper-7_W0QQitemZ5998168174QQihZ009QQcategoryZ49215QQcmd ZViewItem]OFNA (#87373) Alum Front Shock Tower for PCR [/link]
#253
FL
Ok, hopefully were right, becuase one time I spent hours trying to figure out if the towers on there site were the right one becuase it had the right part #'s and everything but they werent milled, turn out when they took the pic it was just filled onto the non-milled side . its nhappned to my firends on this site before, andthere trying to keep form doing it. So if you call OFNA and they give you the same part # its probably the same situation.
#254
IL
how would this engine work in the hyper 7? i saw one running at the track it screamed.
http://www.amainhobbies.com/product_...oducts_id/7458
im also lookin at this one..
http://www.amainhobbies.com/product_...ducts_id/14042
or this one.
http://www2.towerhobbies.com/cgi-bin...?&I=LXKHF0&P=0
or this one.
#255
GA
I would recommend this one:
http://www.stsmicroengines.com/index...e3fae734d86b92
I went from the mach .28 to this one and the buggy is faster and uses less fuel. It is also race legal with the .21. The STS D21B is a really great engine.
#256
FL
ORIGINAL: Townsley
or this one.
or this one.
[link=http://www.amainhobbies.com/product_info.php/cPath/1_23_31/products_id/9529]Hot Mod Novarossi N21B 2001 BF 3 port Off-Road Buggy Engine [/link]
[link=http://www.amainhobbies.com/product_info.php/cPath/1_23_31/products_id/7060]RB Concept S5[/link]
[link=http://www.amainhobbies.com/product_info.php/cPath/1_23_31/products_id/7027]RB Concept S7[/link]
#257
IL
yea, i need somethin to get me up and over jumps coming right out of a turn. there is only really one strait away and one little strait to gas it up, but other than that, i need quickness and grunt to get it around. the mach 28 just dont have it.
#259
CA
ORIGINAL: junebug48
[8D]hi . that's not them because it's not miled like that it has hole's to lighting it up. trhank's .
#260
Hey guys iv orderd a Hyper 7 mach.28, could anyone give me any general tips for when it comes to running in and getting the basic tuning correct? thanks a lot.
Aaron
Aaron
#261
GA
ORIGINAL: Aaron_Anvil
Aaron
Aaron
#262
CA
ORIGINAL: junebug48
http://cgi.ebay.com/Ofna-Hyper-7-C-H...QQcmdZViewItem
#263
ORIGINAL: Brutus
First you will need to replace the grease in the diffs with 5000 in the front, 7000 in the center and 3000 in the back.
Aaron
Aaron
Thanks for your answers
Aaron
#264
GA
They are greased but you will want to put proper diff oil in them. 5000 in front, 7000 in the center and 3000 in the rear... or whatever folks at your track recommend.
#265
ORIGINAL: Brutus
And it seems as if my breaks are not connected, as i say i havent started the car yet but iv tested the electrics, when i roll the car forward and push the throttle the car stops as i would expect from the clutch engaging, but when i push back the brakes do not slow it at all, you cant feel a difference it just rolls still. I cant think of a reason why the brakes would need the engine running or am i just being a noob?
Thanks again for all your advise dudes
Aaron
#266
Sounds like you just need to reverse the throttle direction on the transmitter, its a switch. Pulling the trigger (accelerating) should NOT slow the car down. The clutch is centrifugal, only when the engine picks up a certain amount of RPM will the clutch engage. Pushing the trigger forward should activate the brakes. Like I say, there's two switches on the transmitter for this, one to reverse steering, the other to reverse throttle.
#267
My Feedback: (138)
[8D]hi . 86atrack4 yes that's the way they are lighten and they are the pcr pro shock tower's but they are not the pbs pcr pro's lol . i saw them on ebay last night and asked him if he had the other one's and he did not have them . thank's .
#268
My Feedback: (138)
[8D]hi . i got my pcr pro stering unit today and installed it that look's diff. then the stock one lol . i also got a new chassis for it and a few other part's but have not installed them yet . thank's .
#271
I'm in the process of producing a carbon chassis for my hyper 7. if it works out, would anyone be interested in buying one? The first chassis 01 pictures are in my gallery.... still work in progress!!!
#274
Nice job man but don't let your wife see that on the kitchen table???????. Hey I was running my VTX ST-1 up down the street getting it set up for sunday and the rear diff blew, smoked, fried, dust , junk,wasted, Now I am pissed off this is ridiculous I think all of the money that I have put into this thing and the buying it at first, could have got a 8ight t RTR and made the up grades on the shock towers and had money for fuel.
#275
CA
I run the 50 wt in the front and 45 wt in the rear....I use the losi oils I find this is really good shock oil. it takes awhile for it to brake down and it's not to much $$$$$
