Hyper 7 outdrive cup broken
Hey guys, a freind drove my hyper into a curb and broke the outdrive on the front wheel, My LHS said they dont make that part anymore so i have to spend $50AUS and buy the full universal section of the car.
My hobby shop wants me to buy the universal hobao joint, which includes the dog bone ect, but hopefully i can just buy the outdrive cup.
Im pretty sure this is the part i need:
http://cgi.ebay.com.au/OFNA-87215-Li...QQcmdZViewItem
Banned
Lachy your LHS is F.O.S. That part is still made as it is the one used on the hyper 8 diffs, tell him to pull his head out of his posterior and get the part you want. And if he says NO again point out that the Hyper 7 w/ Mach 28 is still in production, walk out and get it from www.rc-mushroom.com
hence why i didnt buy it
, Im sure overseas websites have it but i was hoping i could find something in australia? , Can i just use any cups such as losi ect?
will any of these cups work? as they are available close to me ?
here is the link: http://www.*********.com.au/store/ad...780db21732034a
thanks heaps
, Im sure overseas websites have it but i was hoping i could find something in australia? , Can i just use any cups such as losi ect?will any of these cups work? as they are available close to me ?
thanks heaps
Banned
Something like [link=http://www.*********.com.au/store/product_info.php?cPath=34_237_71&products_id=788&o sCsid=402c7d75f41719141d780db21732034a]these.[/link]
ORIGINAL: lachy1
Click the link below for an exploded view of the Hyper 7.
Rotor
http://ofna.com/pdf/hyper7pbs-blowup.pdf
rotor, i think its the part called 19347, bottom left hand corner, the cup around the dogbone has chipped. Smak i think thats the part i need thanks
OK...are you sure it's 19347? Or the optional CVA?
If it's the 19347, you have to buy the assembly.
CVA's you should be able to get all the parts.
Rotor
Rotor
I just bought the part smak said , hoperfully its the right one.
the link is here http://www.*********.com.au/store/pr...780db21732034a
the out drive that you are refering too is it the one that is on the diff or is it the one that goes to the wheels?
and no those other outdrives probably won't be right. they aren't common to all cars but some other brands might work but you'ld have to double check.
If you have ordered the one you linked then i think you ordered the one that goes on the diff.
It has a small groove on it which is the same as the diffs.
What you need it's the longer cup without the groove
hey chris i just found that out lol , wrong part
The one that arrived today was the diff cup that the smaller end of the dogbone goes into, i need the cup that connect to the wheel!.
Just cost me $25....Can you guys please help me find the one i need
********its the cup that sits inside the rear steering nuckle if that helps********
ORIGINAL: lachy1
hey chris i just found that out and im pissed off ! , smak... cough cough..
Sheesh!
Rotor
Hey rotor,
I just looked through the manual and i think the part i need is the CVD wingshaft. The thing is, i need the cup on the end of that wingshaft but i dont need the dogbone, that cvd wingshaft costs $49 at my LHS, so im trying to just buy that cup
I REALLY don't know which part you need...I mean... I know but I'm not taking any chances with you!!!!
Post a picture of the part you want. From the Ofna manual circle it using paint or whatever other software and post it here!!!!!!
This is the part i need, http://www.funnytoyz.com/catalog/eba...obao_87026.jpg
i dont need the dogbone but i need the section at the end, thanks guys, Im pretty sure i cant find this in aus, i can find the part above but i just want that little bit.
That's a CVD shaft...this is what you have?
If so, you need it with the shaft, they don't come separated.
If you have the simple dogbone then you need another part.
The Ofna 19026 cva appearantly does not have replacement parts, so you will have to get the whole assembly. Get it for $41.99 USD here:
http://www2.towerhobbies.com/cgi-bin...&I=LXCVT6&P=PU
Rotor
Rotor
