IS THEER ANY CENTER TORSEN DIFFS FOR AN LX ONE?
CA
RE: IS THEER ANY CENTER TORSEN DIFFS FOR AN LX ONE?
if you are racing torsen diffs arent good .....but if you are just messing around there ok......but no i dont think they have one for the lx one
I won't use this car for racing. It's just for screwing around. If I get into racing ill get something alot better. It will probably stay mostly stock. Just better servos, engine and pipe mainly. Plus I can put all that stuff in a racer later anyways.
uhm isnt the one for an LX comp/pro the same??
cuz my pro has a torsen diff. kinda cool but at the same time kinda sucky
good:
no more screwed up gears
i would say prly inproves handeling
Bad:
if you get stuck its kinda hard to get unstuck
good:
Bad:
Do you know the factory part numbers to your diff I coudl compare them to mine and see if its the same.
