Hyper .21 glow plug eater??
I have a fairly fresh hyper 21 that burns out glow plugs in about 2 min run time. Seems to run good otherwise, any suggestions?
Mine did that at the start, but when tuned it stopped. try leaning it out a bit, if it's still at factory settings, mine used to eat them when it was rich.
CA
try adding a head shim, I had a small block that did that after a bunch of different suggestions the only that did work was the head shim. I think it was something with the compression.
ORIGINAL: tacticalman69
what type of plug and what fuel are you using? If the plug is too hot you will burn them out very quickly and will also depend on the % nitro you are using too.
GA
If the coil is burning out I say you are running to lean. Most engines other then OS run a long plug not a short OS plug. Not sure what yours is suppose to run but I recommend checking.
GA
Just went to Ofna web site and that engine takes a long plug not a short OS. He all so said all most fresh engine and with a OS short plug do not think a rod or bearing is the problem.
