Problems with New RB - S5 engine
Hi,
Looking for some help......
I have a brand new S5 from RB, I am going through the runnning in procedure, The engine turns over fine but everytime I go to start it, the engine seizes. I literally attach the glow start and it seizes immediately.
Any one know what is happening???
If it is BRAND NEW. RBs are VERY VERY Tight when brand new. You will need to heat the engine up to get it loosen up enough to get it past top dead center.
yeah definately heat it up and loosen the plug a bit to start it then nip it up when its running. They are complete pains to run in but the rewards are definately there if you have patience.
