Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC 1/8th Scale Buggies
 Need Help With Hyper7 Engine Break In??help please >
RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
Old 06-15-2007 | 01:46 PM
From: Hamnish, LeominsterHerefordshire, UNITED KINGDOM
Default Need Help With Hyper7 Engine Break In??help please
We do not have a clue how 2 start a new .28 hyper7 sport TQ
why is the pull start so tight??
and just general information on how 2 break it in plz
wb
Old 06-15-2007 | 01:51 PM
Default RE: Need Help With Hyper7 Engine Break In??help please
Sorry I can't type it all out again, look on the last page [link=http://www.rcuniverse.com/forum/m_5979184/mpage_2/tm.htm]here[/link]
Old 06-15-2007 | 11:59 PM
mozzzy_2000's Avatar
NOTE it is important to inspect the engine before run in for debris, clean in parrafin oil , try not to use WD40 or acetone if you can...
OK so lets get down to how you run in an engine
1 Put fuel into tank , Pre heat engine with a hair dryer.
2 Start engine
3 Let it run for 30 seconds while you tune top end to just rich of clean tune
4 Pop it on the ground and play with it ( dont cane the crap out of it yet ok! )
5 Stop after approx 3 mins and cool with piston at BDC
Repeat steps 2, 4 and 5 for between 500 ml to a litre
Thats it !
Ok so why do we do this ? Simple ! the engine needs to produce heat to let the sleeve expand and the best way to do that is to put load on the engine. But why ?
Well if you immagine the top of the piston being cylindrical and the sleeve being tapered then whats the piston doing when the engine is running too cool ? its smashing or linishing its edges off at a far greater rate than desired. After the first 3 mins of run time the engine has done some 60,000 Revolutions.. now if its cold thats when youll do the most damage. Not to mention the lower bushing of the rod taking a pounding.
Old 06-16-2007 | 10:36 AM
Banned
thats a long post just read the instructions or have daddy help you
Old 06-16-2007 | 01:26 PM
daddy isnt intrested m8!!!!!!!!!!!!!!
Old 06-16-2007 | 06:23 PM
hyper701's Avatar
did u get it going yet?
