RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
Breaking in your rc
Old 07-09-2007 | 11:19 PM
Default Breaking in your rc
There was a post where someone had like a correct way of breaking in your car and I know its here but its so far back in the threads I dont even know where to start.If someone knows where it is can you please show me it?Thank you.
Old 07-10-2007 | 09:18 AM
RCtruckRacer's Avatar
Default RE: Breaking in your rc
For someone without a lot of experience, I always recommend following the manufacturers directions. You can't go wrong there. But, I believe what you are referring to is the heat cycle method made popular by Steven Bess and Ron Paris.
Its about pp 3 in this link: [link]http://www.nitroreview.com/hintstips/ParisRacingEngineTuningTechTips.pdf[/link]
Old 07-10-2007 | 01:09 PM
I cant view the link.
Old 07-10-2007 | 03:21 PM
Banned
ORIGINAL: RCtruckRacer
Also made popular by the number of people complaining that they have killed there engine after 1.5 to 2 gallons. Heat cycling is good for the pro racer but for the weekend warrior, the slow idle method works best and is far easier on the neighbours ears.
Old 07-17-2007 | 07:26 PM
ORIGINAL: Da Smak
You have that backwards---the idle method kills pinch and engines in 2 gallons b/c it breaks that tight seal when the engine is all cold.
The "bess" or Paris method makes engines last longer because you're actually getting it up to temperatures (200F) during break in, and fitting the piston/sleeve together at the proper temps.
Idling is good for the pro racer who wants to run an engine the same day right away, and toss it later.
Heat cycle is good for the guy who BUYS his engines because they'll last longer! It's proven, just do a search on any major bulletin board.
