RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
CLEANING ISSUES
Old 07-24-2007 | 01:41 PM
Default CLEANING ISSUES
Hey there!
Im really new at this hobby. Despite of getting my first (and only 1/8th buggy) 3 years ago, I only used it twice cuz then i began the university and I stopped racing. Its been 3 years since last time i ran it. Now, this summer im determined to run it again.
Of course, I found my car extremely dirty...so..
*** Is there anything special I can do to clean it? Maybe taking out servos and using water?
*** Should i do the engine break-in again? I think i should
Thanks a lot.
Tony
Old 07-24-2007 | 01:46 PM
SManMTB's Avatar
Default RE: CLEANING ISSUES
Simple Green + Water + compressed air + WD-40 + more compressed air = car is done.
Flush out engine with fresh fuel, start it and tune it. You can't break in an engine twice.
Old 07-24-2007 | 02:30 PM
ferrarimk13's Avatar
i dont recommend using water, its really a waste, it doesnt clean well. Buy nitro cleaner, it comes in like a compressed canister and it takes all oil residue off the car, and use a toothbrush to screb it down. Compressed air also helps as u can take out the parts, and get rid of all the dirt.
Old 07-24-2007 | 03:01 PM
You don't clean with water you simply rinse with water after using Simple Green or 409 and a tooth brush! I do the same thing! Very little water needed! Then blow it dry with air and thoroughly spray it with WD-40.
Old 07-24-2007 | 03:13 PM
jatoracing33's Avatar
i usualy use rubbing acohol and Goo Gone and scruf it off wit a Q-tip. works good enuff for me
Old 07-24-2007 | 03:27 PM
denatured alchohol works well. i use simple green, wd40, and a brush, metal bristled and a regular toothbrush to clean my car, and a few other things i can't think of right now. just make sure you check and see how the bearings are and if they need to be cleaned out aswell.
Old 07-24-2007 | 05:17 PM
i sadly disassemble everything and check it over and clean it off with simple green and a tooth brush. good idea every once in a while but i do it after every race.
