RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
Hyper 8 problem
Old 07-25-2007 | 04:22 AM
Default Hyper 8 problem
First off sorry if this should be in the radio equipment forum but i seem to have trouble with my hyper 8 at my local track. There is a certain section which is the furthest point from me where i loose throttle control. I still have my stearing but i loose throttle, it then comes back after a while. I have a fail safe installed but i have to have one for my local track. Any ideas
Old 07-25-2007 | 12:31 PM
46u's Avatar
46u
Default RE: Hyper 8 problem
Take the failsafe out and run it one time to see if you still have the problem. I would think they would let you do that at the track just to see what happens. I would think you have the failsafe hooked to the throttle servo correct. What brand failsafe is it?
Good Luck and have fun.
Old 07-25-2007 | 01:06 PM
46u is right. Try adding and subtracting variables until you eliminate the fault. In 46u's case, he's suggesting an experiment to see if the failsafe is to blame. Also borrow another radio Tx and Rx to try. Try it with fresh batteries. Make sure all the connections are tight, wire shielding is intact, and that the Rx (Receiver) antenna isn't damaged.
If it works better with another radio set up, then it is probably time for an upgrade.
Do you have the Hyper 8 RTR or Pro? What I'm getting at is what type of radio gear are you using and what is its general condition. Keep a notebook journal when troubleshooting this issue, that way you don't forget all the combinations you've tried during your testing. Always saves me time.
Another simple range test is to have a buddy hold your bug and you slowly walk away from it while continuously blipping the throttle and giving steering inputs. When it stops responding, you'll know what the approximate range of your Tx is. If the furthest point on the track from the driver's stand is greater than this, you know you're going to have issues. Elevation changes throughout the track may also affect signal range/propegation.
Old 07-25-2007 | 01:47 PM
46u's Avatar
46u
According to his signature he has the RTR now weather he still has the stock radio or what I do not know.
Old 07-25-2007 | 04:11 PM
indeed i unfortunately have the stock radio
